Home > Maintenance & Mods (L322) > Help! Whine driving me crazy!
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I have a whine coming from the central counsel it sounds like a dodgy fan bearing. Starts when you unlock the car is not affected by the ignition ( runs with the ignition off). It’s not the main heater air con blower fan that’s fine it’s is a constant speed. Stops sometimes other times will run for an hour or more still runs when you turn ignition off and lock the car so presumably shuts down with the other delayed shut down devices.
Any help identify the culprit and where it is located very much appreciated!!
Post #596776 7th Jun 2021 8:22pm
stuart_2006
The small cooling fan in the ECU box under the bonnet, which exhausts into the main ventilation duct so the noise can appear to come from the centre console? Does it occur mostly when the engine is hot, and/or on really hot days, when the ECU box will be hot?
Post #596784 7th Jun 2021 10:48pm
