![]() | Home > Technical (L322) > Absolutely nothing on final (cranking) position of key |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 786 ![]() ![]() |
The ignition switch is a known common failure on this model - there are a few threads about it on here |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
I am fairly sure that your ignition switch is faulty, I got the same with mine. Steering unlocked, steering wheel moved to position, all dash functions were correct, but no click or cranking over whatsoever. Looking at the ignition switches, it looks like yours will be the same as on an 06 Td6. Cost about £50 ish
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Workshop Manual, free download in the WIKI... link top right of page... |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Morning, speaking from experience, changing the ignition switch on the later model year L322s with the switch higher up, it's a right work up. You have to remove god knows how many trims in order to access the 3x torx screws without damaging anything. I would respectfully suggest eliminating other problems first, not least the starter itself. You can check this by shorting the terminals on the solenoid but for heaven's sake be careful doing this.
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 109 ![]() ![]() ![]() |
been having a similar issue with my TD6 which appears to trace back to slightly loose battery terminals, they appear to be moving whist the car is travelling and just making contact enough for radio dash lights etc but not for cranking next time you turn the key - repositioning solves (for a while), currently they are both cable tied so not to move whilst I investigate alternative clamps. |
