Home > In Car Electronics (L322) > 2008 Audio/head unit fault
rar110
Hi everyone
I have searched the forum but not come up with a clear answer.
A few weeks ago the audio system started malfunctioning. The audio system started this cycle. The head unit would freeze, there would be a sharp noise through speakers and radio would stop for about 8 seconds, return to normal for a about 20 seconds, then repeat. While it was stopped the orange light on the volume button would flash. The reverse camera all worked ok.
Now when I start the car the normal Land Rover splash appears on the audio screen, the orange light on the volume button flashes constantly, and the screen stays locked in that situation. No audio, none of the head unit controls respond, and reverse camera image doesn’t appear. Just stays locked on the Land Rover splash screen.
Otherwise the car functions normally.
The GAP IID tool throws up the following fault message after clearing other faults:
IPC-Instrument Pack
U0248-87 (2F) Lost communication with remote driver utility module - Bus signal/message failure - missing a message
Any advice would be appreciated. Thanks. ______________________________
Post #597272 13th Jun 2021 2:46am
rar110
Just to clarify, I ran the IID tool scanner over the car when the intermittent audio problem appeared. The IDD showed the same fault. The below fault is from two weeks ago.
IPC-Instrument Pack
Post #597273 13th Jun 2021 2:50am
rar110
Also, I did review the below wiki post.
https://www.fullfatrr.com/forum/topic24270.html
I have checked the fuses but not done the hard reset or bypassed the Nokia unit as I would like phone connectivity. I assume this is what Nokia unit does. ______________________________
Post #597281 13th Jun 2021 7:54am
bikeman
Australia
Hi, I had a similar problem a while ago. It turned out to be moisture getting into to LH rear compartment where all the phone, tv, DVD stuff is. I replaced the phone module, which was the culprit and all was good. Apparently if moisture gets into any of the modules it can affect all of them as they are connected via a fibre optic cable, which hates water. Water can enter this compartment via a blocked rear sunroof drain. I hope this helps.
Cheers, Phil.
Post #597282 13th Jun 2021 8:51am
rar110
thanks, I'm assuming Brisbane humidity has finally had an impact. Even though its winter here in SH.
I will try one or two more tricks then look toward buying another Nokia unit. ______________________________
Post #597288 13th Jun 2021 11:27am
Weegie
Bypass the Nokia unit to establish if it is that before buying a new one. John
GAP iiD BT-Sold
Post #597308 13th Jun 2021 1:32pm
rar110
Thanks. Good idea. ______________________________
Post #597372 13th Jun 2021 8:58pm
rar110
Today I finally got around to by-passing the Nokia unit. But no change. Any other suggestions? Thanks.
Post #600435 13th Jul 2021 5:33am
ash27
Did you wrap that at all? I did the same in mine but wrapped it all with black electrical tape.
Logic being it’s fibre optic and therefore light signals.
Might be worth a go. 07 4.2 Supercharged
Previous:
2011 Volvo v70 D5 | 2009 Honda S2000 | 2010 Mazda MX5 2L | 2006 Vauxhall Astra VXR | 2002 Hyundai Coupe 2L | 2002 Saxo VTR | 1999 Saxo 1.4 | 1999 Saxo 1.1
Post #603777 14th Aug 2021 3:35pm
rar110
Thanks Ash. Finally got back to this. Wrapped it all up in black tape. But no luck unfortunately. ______________________________
Post #605043 28th Aug 2021 2:25pm
rar110
All resolved. It turns out the problem module was a Mobridge digital radio receiver I added. Currently by-passed. Will disconnect power and remove eventually. ______________________________
Post #615604 10th Dec 2021 1:52am
