![]() | Home > For Sale & Wanted > [for sale] iid non bluetooth |
jordon0 Member Since: 06 Mar 2016 Location: derbys Posts: 54 ![]() ![]() ![]() |
bump
Broombrooma Member Since: 10 Mar 2021 Location: London Posts: 27 ![]() ![]() ![]() |
Hi Interested in this, does it use usb to connect to laptop?
hi it uses USB to connect to computer
Thanks, I will have a think about it and do some more reading regarding the laptop connectivity. |
Ianb4310 Member Since: 21 Sep 2017 Location: Gainsborough Posts: 201 ![]() ![]() |
Will it edit the ccf files via a laptop? |
in all honesty I do not know if you can adjust ccf with lap top
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 546 ![]() ![]() ![]() |
I *think* it can be used on anything pre face-lift (ie some 2009s) as the face-lift models don't have the LCD display. 2016 Skoda Octavia VRS Estate
parvezsaleh Member Since: 08 Jun 2021 Location: London Posts: 14 ![]() ![]() ![]() |
Hi - this is something I'd be interested in. I've recently purchased a L322 2004 Petrol V8. I'm using Autel for a lot of the basics but need something that can give me a finer detailed set of codes on some of the ECUs, for example I'm seeing an electric thermostat problem but not the exact code (car runs perfectly and thermostat is operating as expected).
Hi Jordon1
