Home > Maintenance & Mods (L322) > TD6 transfer case nut
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
Hi all,
Am trying to change oil in transfer case( td6).
Can get fill plug undone,but empty plug is being a Censored to undo. Big Cry
Have tried with spanners ( 5/8 and 16mm) both start to round the plug,dont wont that.
Cant get a socket with rachet on it because of the protection pipe being in the way. Evil or Very Mad
So any hints as to how I can undo the nut so I can change the transfer fluid most welcome.
TIA
littlecub
Post #597400 14th Jun 2021 3:26am
Are you certain it is 16mm? Do you have a six sided ring spanner ?
Last resort, if you have a nut / bolt removal kit, try that ?
Or last last resort hammer and cold chisel to get it moving .
Post #597415 14th Jun 2021 8:36am
Merchy
As in the above post, 6 point spanner plus it may be worth trying one of the 'Freeze off' type sprays, may help.
Post #597419 14th Jun 2021 9:20am
littlecub
I,ll have to go buy a 6 sided long handle spanner and I,ll try some anti freeze stuff on it as well.
Thanks guys
Post #597538 14th Jun 2021 9:33pm
