![]() | Home > Maintenance & Mods (L322) > Fault Code: P023D-22 (2F) - Any idea's |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
That basically means the pressure measured by the MAP (Near air box) is providing a different reading to Sensor A whish is inside the air intake. (IIRC)
kenneally_mark Member Since: 09 Jun 2021 Location: Cork Posts: 74 ![]() ![]() ![]() |
Thanks for the detailed reply!
Mani absolute pressure 1 : 100.0 kPa
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4351 ![]() ![]() ![]() |
Best way to diagnose a potential hole/crack/split in the system is with a HIGH pressure smoke test.
Cool! Thanks for the advice, any idea on a brand or make so I can buy one? |
Jazzy Member Since: 29 Jan 2021 Location: Worcestershire Posts: 11 ![]() |
Take the top two hoses off and have a look.
There are a few home made smoke machines using a cigar on youtube... Hope that helps sir |
Thanks for all the replies! I've ordered 4 new hoses from my local LR garage. They should be here by Friday so I'll keep you guys posted. I'm also bidding on a leak detector machine to have even if the issue is fixed as all four cars are Turbo cars.
I can confirm they are intercooler hoses, took me 15mins end to end
So thanks to everybody who replied on this topic, I appreciate it.
