![]() | Home > Technical (L322) > Park Brake Fault - Safe To Drive? |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2715 ![]() ![]() ![]() |
One of my caliper motors failed the other month & would not disengage the handbrake, if its running free with no heat build up, you’ll be fine to drive it , but get it looked at sooner rather than later . Mine started the same as yours then eventually jammed on making it undriveable. |
