![]() | Home > Technical (L322) > TDV8 EGR replace |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1344 ![]() ![]() ![]() |
I'm watching with interest in the results. |
Simran0211 Member Since: 10 Jun 2016 Location: Coventry Posts: 300 ![]() ![]() ![]() |
Further update I’m waiting for parts as the water outlet and thermostat housing are both cracked and as luck would have it caught it at the right time. And also rain has stopped play |
Could you see anything physically wrong with the old unit? Cheers Kev. |
No I can’t but what I have seen it could be the valve that’s electric on the side that maybe the culprit I’ll have a look tomorrow as I’m busy watching THE MATCH |
Also the DPF filter is saying that it’s full |
Almost finished just need to change the oil then fire her up |
Fingers crossed for you mate. |
Well the oil arrive to day drained the old stuff and replaced fresh antifreeze started her up and it threw more codes at me but the old code for the whole job had gone only to be replaced by the following
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2751 ![]() ![]() |
The faults are referring to the sensor located in the left exhaust manifold. Was it disconnected and not reconnected? Its connector is in the vicinity of the rear of the left inlet manifold. |
Hi graemes is that looking from the front of the engine I had that off and out when doing the above work. I will check it tomorrow again. Many thanks it does it |
