Wobble when foot off throttle and gear change. | |
Range Rover Vogue SE 4.4 TDV8 2011
On a straight road the car occasionally gives a bit of a wobble or shimmy. Seems to be at around 50mph usually when it changes up or when taking foot off throttle. It’s as if there is a rut in the road but obviously there isn’t. Checked tyre pressures. No fault codes. Wheel nuts all tight.
Could it be suspension related eg something shifts slightly due to torque changes at gear change or power off?
Or some gearbox/drive train problem?
Any thoughts?
David
