Home > Technical (L322) > Wobble when foot off throttle and gear change.
Dstew
Range Rover Vogue SE 4.4 TDV8 2011
On a straight road the car occasionally gives a bit of a wobble or shimmy. Seems to be at around 50mph usually when it changes up or when taking foot off throttle. It’s as if there is a rut in the road but obviously there isn’t. Checked tyre pressures. No fault codes. Wheel nuts all tight.
Could it be suspension related eg something shifts slightly due to torque changes at gear change or power off?
Or some gearbox/drive train problem?
Any thoughts?
David
Post #599992 8th Jul 2021 6:29am
Sounds like play somewhere, take it to a garage and get them to check the suspension and steering joints for play, front and back...
Any MOT garage should be able to do it, doesn't have to be a specialist... Thumbs Up Pete
-Click here for Thread-
Post #600019 8th Jul 2021 10:45am
