Home > Technical (L322) > Steering rack prices (rip off)
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
So I had my overfinch in for a replacement intake manifold and service, £1200 all in. I knew I had an intermittent oil leak, one week it wouldn't leak the next it would though not much at all, slight spotting now and then. The Indy cleaned all the oil away and couldn't spot the leak but the week after he found it. It's coming from the steering rack, price quoted £2200 for a new one, turns out it's a land rover part only. I did some research and a company in Bristol does a reconditioned one for £325 new for old with a 3 year's warranty. £2200 seems rather excessive for a steering rack or is that LR just making a huge markup on spares? At that price i want it in gold with diamante encrusted joints and I want it delivered by a butler in a Rolls Royce and handed to the mechanic on a satin cushion. But joking aside, is that the real cost of a new steering rack? And does anyone have the part number for it please so I can double check? Mine is the 3.6 tdv8 2008. Though would I be right in thinking that steering racks are standard fitting throughout the L322 range?
Post #599981 7th Jul 2021 11:28pm
You can get it even cheaper if you have the time... Thumbs Up
https://www.ebay.co.uk/itm/261595598915?ss...1438.l2649 Pete
-Click here for Thread-
Post #599986 8th Jul 2021 12:17am
kevinp
I had one fitted under warranty and the final bill was £3400!!!!
Post #599987 8th Jul 2021 1:06am
Merchy
Haylands answer is the one to follow, unless you have a specialist refurbishment company near you.
Unless you are seriously unlucky, you will NOT need a new rack.
Due to my background I have overhauled a couple of racks myself on my garage bench, if I can do it, it's not rocket science, to say the least. Whistle Basically new items to change are seals, 'O' rings, bearings, bushes etc.
Get a good Indy to remove it and send it for a refurb and refit Thumbs Up
No wonder we use the term 'main stealer' Censored
Post #599990 8th Jul 2021 2:09am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Had a similar issue when I bought a new to me 2010 322. New prices were mental, as I’d only had it 2 weeks, it was being covered by the ropey 2nd hand car dealer warranty which wouldn’t stretch to the huge expense main dealers wanted. I ended up with a remanufactured rack which iirc was around £700 ish plus fitting, which took it to just over a grand all in . Getting a remanufacture is money well saved as long as you have alternative means of transport. Think they are ZF units .
Post #599997 8th Jul 2021 7:38am
ur20v
A Trap
Price is on par with other similar brands…. It’s not a corsa or escort. 2-3k for a rack is no surprise to me. This is a large luxury car, servicing and maintenance costs are similar to BMW, Mercedes etc.
Post #600013 8th Jul 2021 9:51am
Barmybrummie
Due to work commitments, no space at home or the inclination in overhauling it myself, refurbished is the way to go.
Still a hefty price to pay though for a steering rack, I thought a few hundred pounds, which would be inline with the car. I'm going to give Western power steering a call in Bristol, they have fantastic reviews.
Post #600067 8th Jul 2021 5:00pm
knwatkins
Lion Automotive come highly recommended on the Disco forum for reconditioned steering racks.
It's probably worth giving them a call... https://www.lionautomotive.co.uk/ Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #600099 8th Jul 2021 10:39pm
Barmybrummie
Thanks KN I've just sent them an email. See what they can do for me. Would I be right in thinking that new racks need to be programmed to the car?
Post #600128 9th Jul 2021 9:15am
knwatkins
I don't believe so. I think it's just a case of removing the old one and refitting the new one.
Lion have the L322 racks on their website @ £199. Kev
Post #600133 9th Jul 2021 9:45am
Pawl
No a replacement rack doesn't need any programming.
Fit, fill with fluid, bleed & test & then forget / use as normal.
I was really lucky & got a good second hand rack via local RR breaker for £90 & was able to fit it myself. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #600186 9th Jul 2021 10:56pm
