![]() | Home > Maintenance & Mods (L322) > N/s air filter box removal. |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 787 ![]() ![]() ![]() |
Hiya Dave I removed mine the other week and just pulled it up and it came out rather easily. If everything is disconnected then give it a good pull up and it should pop out. It's only held in by a plastic ball that fits into a rubber cup underneath it. You may need to push it to the left a little bit too free it from the rubber cowl that goes into the wing. Hope this helps. |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Thanks for your help and confirmation that it’s possible to get this out next time. I was looking at changing the fuel filter but found a good way to do this on YouTube by a chap named Pat. Care needed in putting it back together again but a quicker way to do it. |
