Home > Maintenance & Mods (L322) > Deployable Side Steps for 2012 L322 4.4 TDV8 Westminster?
maRRty75
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hi all, I'm a newbie here. Just about to pick up my first FFRR - a MY12 Westminster. It has original fixed side steps, which look pretty worn out. I'd like to explore fitting deployable side steps and have found some older posts on the forum encouraging.
However, it seems no one sells genuine LR deployable side steps any more, not even on eBay!
Can anyone point me in the right direction, if there is one? Am I right to assume LR no longer makes these and all UK stock has gone? If so, are there any other options available (i.e. non-genuine LR)?
Post #600438 13th Jul 2021 7:45am
welcome to the forum..
indeed at one time you could buy these steps in your local 'poundshop' as there were so many about and very well priced...now they are like hens teeth and if you do find some , a bit expensive....
good luck on finding a supplier.. ... - .- -.
Post #600439 13th Jul 2021 7:58am
maRRty75
Thanks Stan
Post #600440 13th Jul 2021 8:05am
kevinp
Try ringing 'The Vogue Centre'. I rang last year and they had some for them to fit. Very expensive though.
Post #600445 13th Jul 2021 9:02am
maRRty75
Nice one, I'll give them a try.
Post #600447 13th Jul 2021 9:49am
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
This company also supply side steps. I think they quoted me about £1200 for them.
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #600453 13th Jul 2021 10:39am
kevinp
I looked at them Ivan, and thought it was for the newer shape cars only. Be interesting to see if they do them for the older cars as well.
Post #600458 13th Jul 2021 11:28am
maRRty75
Thanks Ivan. I contacted Pegasus yesterday and they do not supply/fit deployable steps for the L322, only the newer models.
Post #600460 13th Jul 2021 11:32am
I think Powerfulukltd have some? Thumbs Up
Post #600489 13th Jul 2021 1:52pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
they're nice for about 3 years then the brackets seize up because they are a truly crap design. no oiling or anything else can help in my experience - they're doomed from the moment you fit them 2010 VSE [Roger]
Post #600501 13th Jul 2021 2:47pm
