Home > Maintenance & Mods (L405) > Vibration From Front Passenger Door - Fixed!
knwatkins
I'm not one for playing loud music but ever since I've had my L405 something on the front passenger door has resonated at a particular frequency when certain songs are played at a moderate volume. I always thought it was some loose plastic trim on the doorcard itself or maybe the screws on the speaker had loosened over time. Today, I decided to investigate!
I played a song through the stereo that always makes the door vibrate and no amount of touching the trim on the inside made the noise disappear which lead me to believe it was something inside the door itself.
So, the door was stripped down and I found the offending part, which was the strengthening member running through the inside of the door...
I found that this part is fixed inside the door by a bolt located in the door jamb. The bolt was loose. A quick tighten up with a T40 screwdriver and it was problem solved! Very Happy
I hope this may be of use to someone in the future and saves them time as the bolt is fully accessible without removing any of the door trim. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #600557 13th Jul 2021 9:27pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Thanks for posting, great info!
Post #600571 14th Jul 2021 12:37am
Thumbs Up Thumbs Up Thumbs Up Bow down
Post #600573 14th Jul 2021 12:43am
