![]() | Home > For Sale & Wanted > [Wanted] Drivers mirror glass needed |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
I got one of these and it's perfect.
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Thanks for taking the time to send the link mate got one on order, how did you get on removing and fitting the new glass 2012 Range Rover Westminster 4.4 TDV8
Easy, just gently prised it off with fingers (being careful not to damage the wires behind!!), lined up the new one and gently pressed it in. |
Thanks for the info 2012 Range Rover Westminster 4.4 TDV8
I may have used a protected screw driver to get the initial movement away from the housing. |
