Home > Maintenance & Mods (L322) > 3.6 TDV8 - How easy to remove injector 2?
garyRR
I have had the fault code for injector 2 pop up intermittently, saying:
P02A0-00 ( 68 ) Cylinder 2 balance - injector restricted
Cylinder 2 is thankfully right at the front of the engine, with a fair amount of space around it so, I'm hoping there's a way to get it out without an engine lift.
Has anyone removed one similar before? Any tips or instructions and tools required? 2015 Range Rover Autobiography 4.4 SDV8
Post #600975 17th Jul 2021 11:33pm
kbald
This should be easy enough to remove the hardest part will be removing the metal cover that goes over them. If you look at the end replacement guide that will give you the steps to take to get too it. The only one that needs an engine lift oh the right hand side is the rear one. Current 2007 TDV8 Vogue Buckingham Blue
Post #600991 18th Jul 2021 8:41am
