![]() | Home > Maintenance & Mods (L322) > 3.6 TDV8 Pressure Build up in Expansion Tank |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Get a sniff test done at an MOT station, any signs of exhaust gas in the coolant bottle confirms a head gasket issue.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
If I'm right, and that's always very debatable, if water enters the oil through head gasket failure then yes, you get mayo. But, on the other hand, if water is escaping into the combustion chamber [again through head gasket failure] then it'll simply be burnt off & out through the exhaust system, the latter however normally gives white smoke out the back.
If there is a headgasket failure to the combustion chamber, the pressures are much higher in the chamber than in the cooling system. Logic dictates that combustion gasses would enter the cooling system not water into the combustion chamber. I have seen many head gasket's failed and many people state the white smoke / steam, I'm never yet seen it only the water in oil or the cooling system being pressurised.. BMW i3 Electric Car
.....meaning pressurised water escaping from the nearest point........expansion bottle!
Exhaust gasses in the expansion bottle is a sure sign of head gasket.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Expansion bottle has been changed, I just spent 15 hours replacing the thermostat housing and EGRs because that's what the garage said it was.
