Home > Maintenance & Mods (L322) > DIY oil change on a slope
Rambles
Does it matter how the car is oriented on a slope when sucking the oil out through the extractor pipe next to the fill opening?
Is the ideal orientation to extract max oil with the rear of the car lower than the front ? Ie parked with the nose facing uphill?
And with the Rear offside tire lower than nearside?
Slope is about 1 in 20.
Thanks
Post #601414 21st Jul 2021 6:40pm
AJGalaxy2012
and your engine is ???????? BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #601421 21st Jul 2021 7:39pm
Baltic Blue
I have exactly the same problem because my drive slopes.
However I have bought a pair of plastic car ramps which I find best placed in front of the rear wheels, so that when I drive up them the car is dead level.
Mike
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #601424 21st Jul 2021 7:47pm
Rambles
Nice one Baltic.
Looks like you have the same degree of slope.
What results did you get on the slope when using a vacuum pump?
Post #601445 22nd Jul 2021 8:38am
Baltic Blue
I didn’t want to try sucking the oil out with the car on a slope because it would be impossible to get an accurate reading of the new oil when refilling.
Once I levelled up the car as shown then draining and refilling was very simple.
Post #601448 22nd Jul 2021 8:43am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Just out of interest, what make are those ramps you're using ?
Post #601451 22nd Jul 2021 9:39am
Baltic Blue
https://www.ebay.co.uk/itm/RHINO-RAMPS-HEA...635-2958-0
eBay link…
Rated at 5 tonne, I like them because they are very wide and easily take our width of wheels.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #601461 22nd Jul 2021 11:20am
batfink
Thanks, I thought they might have been but thought I'd better check.
Cheers Thumbs Up
Post #601465 22nd Jul 2021 1:00pm
