Home > Technical (L322) > 4,4 TDV8 suspect intercooler hose leak
NeilTDV8
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
Hi everyone, just done a regen on my car, while on the motorway i gave it a blow out ! anyway i started to hear air gushing sound coming from the passenger side ! i have looked under the bonnet and can see in that area some oily residue at the back of the engine also in the same are underneath the car , will it be a intercooler pipe ? i also got restricted performance message and limp mode. What sort of job is it to change the pipe if it is that ? Its a L322 2010.
Post #601468 22nd Jul 2021 1:39pm
DrRob
Could be a whole number of things. Take it to a decent local independent specialist for a diagnosis.
Mansfield 4x4 get good reviews. Near you? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601481 22nd Jul 2021 3:34pm
NeilTDV8
found the problem, one of the 4 small hoses that connect the inlet manifold to the rocker cover/manifold ! Phew relief its a simple fix.
Post #601508 22nd Jul 2021 7:13pm
DrRob
Original ones were Censored
Lots of folks upgrade to silicone ones cut from a single length.
Lots on here about it with a search Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #601564 23rd Jul 2021 8:29am
