Home > Technical (L322) > oggy needs some help to id some items
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi can you help can someone tell me what are the items in the pictures . this is looking in the boot on rear panel on left side is this heavy earthed block of 3 cables i would like to turn it so the cables will lie better on the back panel can i twist it or does it need to stay in this position . the one on the right side is behind the wheel stop brackets in the right corner . and would this have been the make of the tyres from new as this wheel has never been fitted and tyre is new 255/50/20 thanks for your help this is on a 4.2 supercharged
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #601642 23rd Jul 2021 8:05pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
First thing to check on the spare tyre oggy is the dot date? If it's never been used then the chances are the tyre is scrap as it's been on the wheel since the day it left Solihull and been sat in the back for 14 years. I found that out myself with mine and was rather chuffed until someone on here pointed out the dot date and sure enough, made in 2008 and 13 years in storage. Tyres I believe only have 8 year life span legally.
No idea what the other things are, I'm sure someone with more knowledge than me will tell what they are.
Post #601709 24th Jul 2021 3:21pm
oggy
hi yes i will check i do no what you mean it has come in to the mot now i put one on a pick up a couple of months ago and it was the spare 2003 brand new tyre i will have a look tomorrow and report back thanks for your comments oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #601717 24th Jul 2021 5:38pm
