![]() | Home > Technical (L322) > Am I a dipstick? What is this thing? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
That’s the hole where you use a vacuum pump to drain/remove the oil from above.
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 ![]() ![]() ![]() |
Just the one in the driver's seat then 🤣
You can... but it’s much faster and easier from above. You need a suction pump. Have a search on the forum.
Thanks for the info, I did check it via the service menu but thought I'd verify that with the analogue method 🙂
Dipstick..... |
