Home > Maintenance & Mods (L322) > How to Remove RSE Centre Console AV Panel?
garyRR
Does anyone know how to remove the little panel by the rear seats with the 12V outlets and AV inputs in the centre console?
I want go do a neat little mod where I remove the 3.5mm jack, blank it off on the panel and hide it in the centre console, leading a 3.5mm cable into the arm rest, where it plugs into a bluetooth receiver.
This is a neat little mod someone had done on my old RR, which I want to replicate on the new one for Bluetooth streaming.
 2015 Range Rover Autobiography 4.4 SDV8
Post #601914 26th Jul 2021 10:33pm
mjdronfield
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #601917 26th Jul 2021 10:59pm
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
FYI - I went down this road
https://www.fullfatrr.com/forum/topic58324.html
Works well (my hack job leaves something to be desired) 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #602097 28th Jul 2021 3:51pm
garyRR
I will try tonight and post photos. 2015 Range Rover Autobiography 4.4 SDV8
Post #602099 28th Jul 2021 3:53pm
muddycharles
Disasemblng the console
FYI - it was an easy job as per the documents. The hardest part is removing the screw that holds the top armrest in place. Its long and needs to have retaining clips removed on both sides.... You can break these and thats not good.
I searched online (YouTube with powerfulukltd) and here to find comments on how to do it.
Make sure you figure that part out (the bolt mentioned above) 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #602100 28th Jul 2021 4:03pm
garyRR
So, I had a fiddle tonight.
No need to remove anything other than the bottom cowling and the 3 screws holding the AUX inputs. The unit then drops off and just 2 multi-plugs to remove.
Despite trying to trace the tracks on the PCB and a bit of fiddling with a 3.5mm cable with the end cut, I could not figure exactly which cables on the ribbons are used in order to splice into them.
Unfortunately, after a bit of fiddling, the connections inside the 3.5mm jack are now loose and I need to buy a new module - doh!
So, if you don't have RSE, you're in luck. You can unscrew the unit and there's a little ledge to put it on behind the centre of the arm rest. Then it's just a case of drilling a hole and feeding a 3.5mm cable through.
For RSE, an auto electrician may be able to trace the ribbons and splice in but I couldn't fathom it - trying the L and R feeds from the Jack only resulted in mono high range sounds through the car stereo. I think therefore, the solution is to purchase a 3.5mm cable with a 90 degree end. This will allow the dust cover over the AUX inputs to be closed and, feed the cable under and through the centre console, drilling a small hole for it in the arm rest. This seems the neatest install option with no cable on show. 2015 Range Rover Autobiography 4.4 SDV8
Post #602128 28th Jul 2021 9:40pm
