Home > Maintenance & Mods (L322) > oggys mods air suspension pump case or box
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
i had to replace the air sus pump and it was a bit of a fiddle so i made some mods to make it easy for next . i would like to say a big thank you to haylands for all of his help in this matter sorting out the codes that it was the pump that had failed great help to me and he knows his job well like so many more members on this forum and big thanks to all . so hear we go .. i done away with the bolts and cut some stainless steel thread bar about 70 mm leaving 50 mm above i then thread lock with 271 red and left overnight then put rubber washers over top for the bottom plate to sit on i then cut some heat shrink just leaving a nuff for the washer and nut to go on top slid bottom plate over and stuck the washers to the bottom with pu sealer . and then put the cradle over thread bar in place dropped top washers on and then the nuts and to stop any rub near the thread i put some caps on top job done nice and easy for next time
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #602432 31st Jul 2021 8:06pm
Glad you got it sorted.. Thumbs Up Pete
-Click here for Thread-
Post #602442 31st Jul 2021 9:17pm
