Home > Technical (L322) > 4.2 air cooler question
Danwilderspin
Quick question - the two metal air coolers that sit after the supercharger either side, if I were to tap a vacuum line from there would it always be vacuum regardless of revs or would at a certain point in the range it switch to boost?
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #602515 1st Aug 2021 6:51pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi,
Are you sure that there is vacuum / under pressure over there Sir?
Post #602533 1st Aug 2021 9:28pm
Danwilderspin
I assume so at idle? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #602542 1st Aug 2021 10:27pm
Piet
I'am not sure but ill think not Sir.
Look on the at-her site of the SC. (suction side of the CS)
Maybe T connection on the vacuum lines which are connected to the elbow?
Post #602551 2nd Aug 2021 6:30am
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Piet,
I agree with you. Thumbs Up
Regards
Post #602555 2nd Aug 2021 8:07am
Danwilderspin
Thanks Piet the bit you are holding the supercharger bypass I think it is if I T into the line going to that would that be best? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #602558 2nd Aug 2021 9:11am
Piet
Yes, Ill think thats best
You are than between the trottle valve and the SC, for sure there you vacuum.
Do you want it for for the LPG?
Post #602560 2nd Aug 2021 9:31am
Danwilderspin
yes hats what I was thinking and yes for LPG Smile thanks! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #602562 2nd Aug 2021 9:51am
