![]() | Home > Technical (L322) > Ignition/Light issue |
24valve Member Since: 07 Apr 2009 Location: Cornwall Posts: 166 ![]() ![]() ![]() |
I wonder if anyone can help.
on top of the above stuff, I've now taken out quite a few fuses, disconnected the brake light pedal switch, transmission control ecu and charged the battery.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
i recall its something to do with the brake pedal switch sticking.. ... - .- -.
I've disconnected the brake pedal switch and its still the same.
This morning efforts show that maybe the regrounding with a jumper cable isnt the result I was expecting - and its still the same.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
That last bit sounds like high resistance at a joint somewhere around the battery to starter, could also be a failing starter, can't see how it would give you the other symptoms though...
Thanks for the response Haylands.
Get some diagnostics done then, just replacing stuff get expensive very quickly... |
Fortunately, I'm not replacing stuff at the moment - just disconnecting things.
