![]() | Home > Technical (L322) > Tdv8 3.6 injector values iid tool |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Anbody please. |
nick4275 Member Since: 28 Sep 2018 Location: Bewdley Posts: 69 ![]() ![]() ![]() |
You are right in your thinking.....
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 265 ![]() ![]() ![]() |
What error code/message are you seeing that is suggesting your injector is faulty? |
I'm getting injector balance offset reading which are about 960 to 1150 but injector 3 just before going into restricted performance mode runs down to about 600 while all the rest go up to 1350 1400. Error codes are low fuel rail pressure and low injector pressure 87 and 91. I am just in the process of running out low pressure fuel pump and then it will be injectors out again for bench test and if that's not it then lastly, check for possible dicky senser and or high pressure pump. Tbh I think injectors are leaking off to much but can't seem to run lpfp. Wanted to test tonight but only got as far as removing rear carpet and plugs when I got dark. |
To respond to the two previous posts....
If I can help, read somewhere that they should be between 960 to 1400 the later indicating more fuel being used to balance. |
A bit more info which might help.....
Excellent so numbers on engines ie 1 to 8 are as is on iid tool interface.. I am going to take all of mine out and send for bench test, just need to carry out crued leak test first. Basically have pressure at low pump, pressure at filter both in and out side but soon as its connected to engine pressure is nothing so is a leak somewhere. If I get chance later today I am going to take return pipe of and if diesel runs back without cranking just ignition on, then I have injector internal leak or hp pump issue I reckon. |
Yes that's right IID and numbers etched onto intake covers match.
Thanks I've removed them all and made special tool to fit on engine mount, but yeah still a really ball ache . I replaced intake manifold gaskets and wow for the small oil leak that they produced I wish I never bothered lol. |
