Home > Maintenance & Mods (L322) > Rusty brake joints
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Rusty brake joints
While working on my bushes, I’ve been taking Fisha’s lead and derusting my sub frame and arms ( mean suspension arms… although my arms are also covered in paint!).
Whilst there I also painted my metal brake lines where I could see them as an extra protection. Whilst there I spot this join…
Do I give it a good clean and paint for protection? Am I better off leaving it, or is it in need of replacement? Painting it seems the sensible option, but will that be a problem if I have to undo that bolt at a later date? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #603328 9th Aug 2021 11:15pm
kevinp
You won't do any harm by cleaning and painting. If you do have to remove it in the future the paint will crack off, just make sure the spanner is fully on the nut before you try and undo it.
Post #603341 10th Aug 2021 6:44am
Ffrr-lover
Cheers for the feedback kevinp.
I suspected it would be ok to paint them… just wanted to throw it on this forum should there be any “no don’t do that” comments Laughing Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #603432 11th Aug 2021 7:45am
Weegie
If those are the front flexibles, they were subject to a recall. If they haven’t been done on yours it would be worth exploring with your Main Dealer.
AFAIK there is no time limit. Mine were done here in France FOC, by a Main Dealer and my, originally Brit registered L322, was several years old at the time.
Search the forum for “ brake hose recall’ for more information John
GAP iiD BT-Sold
Post #603477 11th Aug 2021 1:47pm
Ffrr-lover
Thanks for the heads up…
This is the rear. I believe it has had the recall work done, but plan to investigate that when I start work on the front suspension bushings. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #603536 11th Aug 2021 9:32pm
DON'T PAINT THEM..... Take them off and replace them whilst your refurbishing your subframe sir... They run down the rear wishbones and they rot BADLY... So, it's about the right age for yours to be replaced... Whilst you're at it, check the rear brake pipes as they rot too!
Oh and if you want to paint the new ones? Why not Thumbs Up
Post #603539 11th Aug 2021 9:40pm
Ffrr-lover
Cheers Craig. I hear you… but chose the paint option for now. I’ve spent more money than I have at the moment (‘tis the birthday season for our families).
I do however take on board your advice about replacing them… just going to postpone that job.
I want to service the callipers at some point so will probably do those all at the same time. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #603635 12th Aug 2021 7:43pm
Ffrr-lover
Urgh… looks like a sooner rather than later job for those brake lines! I did take a picture but can’t find it… that’s odd…
I finished the LHS bush replacement so started on the RHS. Those pipes are even worse! I’m going to treat these for now too, but then off to Rob @ Duckworths for some prices after looking at what’s involved.
L322 repairs… makes me think of the “and theeeennn…..” scene from “Dude where’s my car” Laughing
https://youtu.be/CkdyU_eUm1U Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #603742 14th Aug 2021 6:47am
I replaced both my rear flexi-pipes a few months ago and judging by the looks of yours, they look very similar to mine and I ended up having to cut them off, as you almost certainly won’t be able to split the pipes at the bracket without ruining it and then adding a new piece of the steel brake pipe (which was rusty) as well as replacing the spring clips that keeps the tension on the joint, as these get destroyed when you cut the pipe.
Not the worst job in the world, but awkward. Got - 2017 SDV8 Autobiography in Loire Blue
Post #603780 14th Aug 2021 3:51pm
They do rot like pigs don't they... Rolling Eyes
Post #603810 15th Aug 2021 12:44am
Ffrr-lover
Indeed they do!
Along with everything else on these cars! I was under the car until late last night cleaning off rust from the subframe before I clean and paint. There is a lot of rust Big Cry Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #603816 15th Aug 2021 8:33am
