Home > Technical (L322) > No revs
William97841
No revs
Hi guys so this has just happened….drive for 50mins all ok although at lights revs was fluctuating. Now pulled up switched off then on again revs are at 0.5prm and won’t rev put it in drive engine still on but revs drop to zero the same for reverse and in park revs back upto 0.5rpm and no codes at all on my gap iid tool. Any help?
Got a video but how do you upload it?
Post #603898 16th Aug 2021 11:13am
William97841
https://youtube.com/shorts/cBSCMQi8KyA?feature=share
Post #603904 16th Aug 2021 12:01pm
accelerator cable broken? ... - .- -.
Post #603905 16th Aug 2021 12:32pm
Stan, it's fly by wire, but you could be on the right track, it could be a faulty accelerator pedal..
You can check this by using the live values section within the IID tool...
Tickover is around 13%, see if it rises when you accelerate. Thumbs Up Pete
-Click here for Thread-
Post #603925 16th Aug 2021 3:15pm
William, what model have you got, your profile says a TD6...? Pete
Post #603926 16th Aug 2021 3:18pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
My guess, a speed sensor in the gearbox, or the speed sensor/ abs sensor, I think it is the right rear one.
Post #603937 16th Aug 2021 5:03pm
William97841
Sorry guys I thought I changed it. It’s a 2007 3.6 tdv8
Post #603941 16th Aug 2021 6:40pm
William97841
The funny thing is I left it to cool for an hr then it worked as normal still fluctuated a bit on tick over but still drove. Just drove another 30miles now no sign of it doing it and still no codes on the iid tool
Post #603942 16th Aug 2021 6:46pm
this member found he had a split hose so i'd check yours,
https://www.fullfatrr.com/forum/topic60551.html ... - .- -.
Post #603955 16th Aug 2021 9:08pm
FYI speed sensor is left rear ABS sensor, if it goes it chucks on loads of faults and lots of warning lights... Thumbs Up Pete
Post #603997 17th Aug 2021 2:55pm
jagracer
Thanks, thats what happens after laying all day under a FL2 trying to fix a dud engine.
Post #604013 17th Aug 2021 5:08pm
William97841
So checked the hoses their all good. Checked the injector values and injector one was 894 and the others in the 950-1095 mark so I think their ok. I was thinking perhaps egrs?
Post #604035 17th Aug 2021 8:47pm
Have you checked the throttle pedal yet..? Pete
Post #604048 18th Aug 2021 12:08am
William97841
Hi Pete sorry had surgery not been here for a week. So throttle works fine been driving it all yesterday no problems done about 30miles in it all ok….but this morning started it up ran for 10 seconds and cut out like stalled didn’t know autos could that along with all the messages engine system fault transmission gears only (missed abit on that one) parking brake fault and got the code p0191-24 and a generic code u0401-00. Never had the p0191-24 and it’s the fuel pressure sensor stays high which I thought was strange. So cleared faults turned off then on just drove 5 miles and it’s purring it’s sooo weird.
Post #604419 22nd Aug 2021 8:36am
