Home > Off Topic > How to remove a snapped SDS drill bit from chuck
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As above, got half the end bit of an SDS drill bit stuck in the chuck, the slotted bit. I’ve tried hitting it, shaking it, WD40 and unsuccessfully prodding and scraping at it with a long, thin screwdriver
Any ideas gents? (sexist assumption I know)
Post #605384 2nd Sep 2021 9:23am
Mr Tee
Might work:
Lever off the rubber chuck cover, pull back the chuck sleeve as if inserting a bit and you will see it is held by a split ring. Revove the split ring ideally with a pair of circlip pliers and the outer sleeve will come off. You may then see a hole beneath the broken piece of drill bit, just lever the broken bit out with an old screwdriver and reassemble.
or, found this on a screwfix thread:
using 5 minute epoxy....
1. Don't try any lubricants in the chuck as you will want to get a good bond on the broken end of the drill bit.
2. Pull back the spring-loaded chuck sleeve, prise off the circlip and slip off the washer and spring.
3. Get a countersunk wood screw with as large a head as will fit down the chuck. File/grind the head to make a better key for the epoxy.
4. Mix-up the two-art epoxy and put a small dob on the screw head. Not too much as you do not want the excess to squeeze out and bond the broken end of the drill bit to the inside of the chuck!
5. Set the SDS drill with the chuck vertically upright. Insert inverted wood screw and press gently square-on to the broken-off end of the drill bit. Pack around as necessary to keep wood screw aligned with chuck while the glue sets-off.
6. Give is a couple of hours for the epoxy to gain some extra strength then try gently pulling on the wood screw.
7. If it does not want to come, and it did not for me, spray a little WD40 or such like penetrating lubricant onto the two small steel balls in the holes in the exposed shaft of the chuck. The grease can have gone stiff and sticky with age and use but they should then drop out.
8. Give it 10 minutes or so for the penetrating lubricant to do its work and pull gently on the wood screw.
This worked for me and the broken-off bit came out easily.
Knowing what I know now, I would try skipping step 2 in the first instance and try to remove the bit without having to dismantle the chuck.
Post #605387 2nd Sep 2021 9:44am
buy a new sds drill.. Mr. Green ... - .- -.
Post #605388 2nd Sep 2021 9:46am
RJPotts
You must work for a LR main-dealer! Laughing Laughing
Post #605439 2nd Sep 2021 8:19pm
