![]() | Home > Maintenance & Mods (L322) > l322 Td6 anti-roll bar |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 491 ![]() ![]() ![]() |
Daft question Merchy but why do you have to get it out? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Not a daft question....
Anyone ????? Has anyone done this without a ramp / lift, car is on drive way on axle stands.
Ah right, if it’s that bad I’d be having a good look at the rest of it, I.E all around the rear end and jacking points before you invest your time in the front to ensure its not not knackered, as they’re really prone to corrosion at the rear, even to the point of removing the plastic sill covers the get a good idea. If all good and you can’t get the roll bar out with the suspension stripped then I suspect you may have to lower the rear of the front subframe to get it out, Ive never had to take one out due to corrosion and I’ve seen a lot of the underneath of them. The good the bad and the ugly.
Had a good clean of the anti roll bar, it is not as bad as I initially thought, rust on body / jacking points is not serious. I have some good quality plastic steel which I will build up on the roll bar,where the off side bush fits on, have used this stuff at sea, it is stronger than the metal as far as wear, and fit new bushes.
The saga continues............................ Boring so maybe avoid if you are busy or do not do your own work, photos may interest some, especially track rod removal for non engineers
As for the new air bag / strut, some people do not like the Dunlop version.
