![]() | Home > Technical (L322) > Suspension fault 30mph |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8718 ![]() ![]() ![]() |
You pull the loom through on the tailgates, no need to cut anything... |
Tiprat Member Since: 05 Aug 2021 Location: Manchester Posts: 100 ![]() ![]() ![]() |
Thank you very much Pete for the reply, firstly I use the Autel because I use it on all my other jobs that I do for family and friends.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
the deployable side steps sieze up whether you hit a rock or not - not much you can do with them except bin them unfortunately.
Put it this way, they don't fit the loom then weld the tailgate together, so, whatever they have done can be undone and redone... There are very small Co-ax leads going to your central locking aerial that are very difficult to join after cutting, and IIRC there are some can bus type leads and you can ruin them very easily... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
