Home > Maintenance & Mods (L322) > Rear caliper question please
Dode4444
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
Hi all,
Trying to find out if my rear caliper brake hose bolt is the banjo style with a copper washer either side etc. Struggling to find info or part numbers if anybody has please?
Have ordered a new caliper and just trying to source all parts in advance.
Thanks. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #606217 11th Sep 2021 7:12pm
Strider
Yes they use a banjo bolt (where it connects to the rear brake caliper).
I bought both sides (they are handed), the numbers are :- LR058025 and LR058026.
They should fit your car but check first.
Post #606221 11th Sep 2021 7:51pm
Dode4444
Thanks very much!
They look like the correct hoses. I was hoping to keep my existing ones is there a washer and bolt kit at all?
Or does anyone know the washer sizes I need? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #606222 11th Sep 2021 7:58pm
Merchy
Copper washer size on a 2006, ( most likely the same banjo bolts ) - ID = 10mm, OD = 16mm, thickness = from 1mm to 2mm, if using old washers or new 'old' stock always remember to anneal them first to get a good seal.
Post #606229 11th Sep 2021 9:53pm
Dode4444
Thank you.
Will look for 10x16 washers 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #606230 11th Sep 2021 10:06pm
Strider
I bought mine from Duckworths (site sponsor) and they came with new bolts and copper washers Thumbs Up
Post #606234 11th Sep 2021 10:14pm
Dode4444
Have already bought my calipers unfortunately they are already on the way. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #606235 11th Sep 2021 10:24pm
Strider
Noooo, the brake pipes came with the banjo bolts and washers fitted.
Also , before fitting the new flex's i got a small tin of Humbrol Black enamel paint and painted the short
metal section of brake pipe in the middle of the hose (this is prone to rusting).
Post #606237 11th Sep 2021 10:34pm
Dode4444
Sorry my mistake haha.
Was hoping to use the original hoses being a tight a*se. 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black
Post #606238 11th Sep 2021 10:35pm
