![]() | Home > General > Removing Paint Specks |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 4014
We had our building painted at work today, unfortunately they didn't tell any of us, and those of us who were parked close to the wall now have black masonry paint speckles from the roller over our cars.
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
I would have said claying as well. Cant think of anything else other than a machine polish. |
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
My golf was speckled with Dulux weathershield masonry paint and it just washed off. 2004 black Vogue TD6 |
Apparently because I have a dark car and it's black paint they don't think it warrants any remedial work. Admittedly you have to look hard to see the paint, but if you run your hand over the surface you can certainly feel it!
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
My fwit neighbour painted his wooden fence recently and used a sprayer. I now have red paint flecks all over the right hand side of the car and all up the front bay window on the house.
| JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889
get a clay bar on this and you will have it off in no time.
| BRUNBERG Member Since: 13 May 2011 Location: Surrey Posts: 37
Snow foam it, clay it with plenty of lube if there's still trace apply an abrasive cleaner such as dodo juice lime prime either by DA, rotary or by hand mate |
| Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78
I agree to what peeps are saying Clay it first.
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Sounds like a great weekend to me! Discovery 4 HSE
I spoke to our COO, who is a car fan and always admires my RR (he and I have the nicest cars in the carpark) he's signed off any remedial work.
Dont know about you Dan Once I have clayed the car! yes its smooth and all that but it does need a good polish afterwards with the swirl remover !! Always seem to show fine lines !!! Or is it just me ! |
Claying shouldn't mark the paint itself, but it does remove previous wax/sealants/fillers. It's this that often makes the car look worse, unless you don't use enough lube, I always use 2 or 3 bottles, but then I make them up myself with water and 25% demon shine.
| HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244
I would suppose after claying its the best to polish the car with a Polisher (rotary or DA) and use some good Products,for example (Meguiars,Swissvax,Chemical guys and many others) I used Swissvax products on my RR and the paint looks sooo much better. If Claying doesnt remove the paint specks you can wetsand. I suppose 2000-3000grit but after wetsanding you have to polish it. Regards Phil |
| All times are GMT |
