Home > General > Access / Travelling Height
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
Hi,
Does anyone have the figures for the actual FFRR height in access mode ?
The brochure gives a figure of 1865mm with a small symbol +, which presumable means this is not fixed (as we know !).
But what I need to know is this the height at access or normal height when driving on a normal road ?
I don't have mine yet to get a tape measure out and want to see if it'll fit in the garage before it arrives ......roll on September!
Also, has anyone had issues getting on the channel tunnel with the FF height ?
Thanks.
Post #65883 26th May 2011 3:10pm
http://www.fullfatrr.com/forum/topic5667.h...ss+heighth
http://www.fullfatrr.com/forum/topic4501.h...ss+heighth
http://www.fullfatrr.com/forum/topic2677.h...ss+heighth
probably more on the search ..
Post #65893 26th May 2011 3:27pm
Restrained Laughing 2008 MY Supercharged
Post #65908 26th May 2011 4:30pm
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Rolo,
With the channel tunnel always go for the over height vehicle option - doesn't cost anymore and gives you so much room to turn into the deck. CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #65915 26th May 2011 5:15pm
Vogue Owner wrote:
Rolo,
only one bad point with this is, that you end up with the coaches full of people wanting to use the only two toilets on the carriage , otherwise its ok...
Post #65917 26th May 2011 5:20pm
Rolo
scarey wrote:
Vogue Owner wrote:
Rolo,
Time to get a portapotty & privacy glass then !
Thanks guys for your input.
Post #66052 27th May 2011 3:05pm
tbh, there are toilets where you queue up to get on the carriages and the journeys only 35 minutes so its not that bad..and a big advantage is that the carriage is more 'airy' than the car ones...
Post #66053 27th May 2011 3:13pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
Or more "On Fire" in some cases !
Post #66056 27th May 2011 3:45pm
