Home > Maintenance & Mods (L405) > Cack ride quality
Mr Tee
Cack ride quality
Not driving it much these days , last was towing the tin tent so tyre pressures increased . Reduced them back down with a digital gauge , however I’m convinced the ride quality is off, just seems completely out of sorts . I have noticed a fluid leak under the near side front headlight area , is there a known weak point there ? Have it booked for tail end of next week anyway , just thought I’d moan here first .
Post #607151 23rd Sep 2021 8:25pm
knwatkins
Your Dynamic Response (hydraulic anti-roll bar) fluid is on the nearside, just behind the airbox on that side. Have you checked your fluid levels? It could be worth doing a quick check to make sure you're not critically low on anything.
Coolant is also there.
Do you know what type of fluid it is? Oily or not? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #607153 23rd Sep 2021 8:40pm
Mr Tee
Ah that makes sense, clearly something is leaking , I’ll have a gander tomorrow. Just wasn’t sure if it was my imagination, is the fluid MD only ?
Post #607157 23rd Sep 2021 8:55pm
knwatkins
Not at all. It's Texaco Cold Climate Power Steering Fluid.
Personally, I use Smith and Allan Cold Climate PSF... https://www.smithandallan.com/products/tra...over-ace-/
The test specs are exactly the same as the Texaco specification. I wonder where they buy it wholesale Whistle
Datasheets for reference:
Texaco Cold Climate PSF Kev
Post #607158 23rd Sep 2021 9:03pm
Mr Tee
Excellent , looks like I’ll need some tomorrow, see if euros or halfords have any , cheers .
Post #607162 23rd Sep 2021 9:43pm
Mr Tee
Got some fluid from local MD, went to fill up, how the hell are you meant to see the level when you can’t see the fluid through the tank? Cue me filling it up to the brim then having to sook some out with a calpol syringe ffs. Drives great though Rolling with laughter Rolling with laughter
Post #607210 24th Sep 2021 3:45pm
knwatkins
Yeah, the design of the reservoir is crap on the L405, it is difficult to see the level. It was much better on the L320.
It does help to shine a little torch through, but it's still not easy, especially if you have nice clean fluid Rolling Eyes
Note that on the 80k or 5 year service, the reservoir is meant to be replaced because it has an integral filter.
Good to hear it's driving better Thumbs Up Kev
Post #607213 24th Sep 2021 4:06pm
Mr Tee
Just been to the garage, leak is from one of the rear dampers, didn’t even cross my mind that if the car is front end in or reversed in the drive it’s the opposite side to the fluid reservoir, silly mistake. Also found another leak from as close as we can see offside front wheel well area, quite wet , looks to have been leaking for a while. Side step is covered fight at the front, looks like there may be a cooler in that region?
Post #607865 1st Oct 2021 3:17pm
knwatkins
There are a few things over that side:
Diesel for the FBH
Coolant for the FBH
Brake fluid master cylinder
That's a shame about the rear shock leaking. Has the garage ordered the parts to repair it? Kev
Post #607873 1st Oct 2021 4:20pm
Double-check the shocker is leaking as most 405's & 322's show damp areas on the rear shockers... That said I have had a couple of 322's have 100% rear shocker failure but they are very obvious... Thumbs Up
Post #607901 1st Oct 2021 10:31pm
Mr Tee
Cheers Craig, I was underneath when it was on the ramp, rear shock was soaking wet Thumbs Up
Post #607911 2nd Oct 2021 8:25am
