![]() | Home > Technical (L322) > Rear heater only blows cold |
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
I assume the rear is set to hot?
| Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352
Yes rear set to hot front about 22deg I tried it yesterday unless the ac is turned off and you want warm up front the rear doesn’t get warm 2012 Range Rover Westminster 4.4 TDV8
I had an issue where the rear wouldn't get hot. (Mine has 4 zone climate)
