Home > Technical (L322) > Heavy steering at low speeds...TD6
Superspoons
England 2006 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Morning,
All is going well with our new TD6 but I've noticed how heavy the steering is at low speed when, for instance, doing a 3 point turn. Anything below 10mph takes a lot of effort to turn the wheel.
Is this a ' feature' of the TD6? My previous 4.4 never had an issue - finger light steering at whatever speed. It's got a years LR warranty so if there is a problem Id like to get it sorted.
cheers, Gavin
2005 Range Rover Vogue SE 4.2 Supercharged V8
Follow my 4.2 Supercharged antics -
https://www.fullfatrr.com/forum/topic63354.html
https://www.instagram.com/l322_supercharged/
https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg
https://www.youtube.com/@ChallengingClassics
Post #65980 27th May 2011 7:57am
Sounds like you need the servotronic valve on the steering replaced
Post #65981 27th May 2011 8:15am
mine had the same symptoms, replaced the servotronic valve [£50/60] and problem now gone..
Post #65986 27th May 2011 8:34am
Superspoons
Thanks for all the replies - This should be covered on the LR Warranty???
thoughts.... Question Gavin
Post #66062 27th May 2011 5:27pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
Yep sounds like servotronic valve, should absolutely be covered under warranty! 2008/58 FFRR 3.6 TDV8 Vogue
Post #66081 27th May 2011 9:56pm
