Home > Wheels & Tyres > Overly large tyres on 22inch rims
jazzdude
Cyprus 2007 Range Rover Vogue TDV8 Java Black
I just bought a 2007 3.6 TDV8 and it has been fitted with 22 inch rims and enormous 285 45 R22 Conti tyres. To these there are also what look like 20mm spacers as well.
Most of the time they are OK but going over speed bumps the back tyres scrape on their outside edges, about an inch in from the outer edge on the wheel arch.
They are unfortunately brand new and dropping another 1200 euros on a new 285 40 R22 set right now seems daft.
So my question is would I be doing any harm to the car leaving them on for a while until they are worn as long as I go easy on the speed bumps?
I'm not sure if anything will improve by removing the spacers.
Post #609372 16th Oct 2021 1:18pm
mjdronfield
For the time it takes, I’d try it without the spacers… though of course the tyres might rub on the inside, but you can always put the spacers back and be no worse off. I’m assuming the spacers have been added for aesthetics, I don’t know the max tyre size that fits under.
Plenty of folk have those 22 inch Overfinch style wheels on, so will be able to advise better.
That said, if you want to go back to standard, you may get more now for your 22s with nearly new tyres…. Just a thought….
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #609373 16th Oct 2021 1:41pm
Vogue
Why not just put it in extended mode going over speed humps 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #609387 16th Oct 2021 3:53pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Maybe narrower spacers will solve the problem? 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #609401 16th Oct 2021 6:19pm
That's a 32" tyre, I had those on fatty off roader, I didn't have spacers but don't know what offset your wheels are, as has been said you will probably get away with a smaller spacer or none at all... the only issue I had was rear off side arch where the fuel filler pipe goes to the tank, had to heat up the arch and persuade it in an inch or so...
A lot of insurance companies frown on spacers so don't forget to declare the mods....
Remember with tyres that size the speedo will now be under reading... ie, an indicated 70 and you will be going faster... only by a few though.... Pete
-Click here for Thread-
Post #609460 17th Oct 2021 11:01am
Bronjen
United Kingdom 2002 Range Rover Autobiography 4.4 V8 Baltic Blue
285/ 45 / 22 are too tall the speedo will not be accurate unless you use an IID tool to recalibrate the speedo,
Post #609601 18th Oct 2021 4:23pm
DBB
United States
If those are authentic overfinch wheels, 22x9.5 ET50, then they should clear without the spacers.
Post #609746 19th Oct 2021 7:45pm
