Home > Maintenance & Mods (L405) > Water gushed out bottom of door - upon opening ?
BLOOM
United Kingdom 2017 Range Rover Vogue TDV6 Carpathian Grey
This morning: opened drivers door to get in... water gushed out the bottom, over the sill and floor.
Confused ... I looked around and saw a funny seal. I remembered that it's always been like that. I spotted it not long after we bought it - but there's never been an issue ... see pics attached.
Any advice appreciated. 67 plate RR.
 '67 Full Fat RR
'64 Discovery IV
Post #608331 5th Oct 2021 2:13pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi you can remove door card, it takes five mins.
This will give you access to this seal, you can then reposition it. The seal just pushes on.
Look on you tube for door card removal from Powerful and they show how to remove card.
Hope that helps.
Post #608420 6th Oct 2021 5:07am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
also check to make sure your roof drains aren't clogged....on my l322 it would occasionally clog and water would gush out the bottom of the door by the hinge (roof drains came out there on the l322...not sure if they are there on the l405 but might be worth checking) 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #608471 6th Oct 2021 1:29pm
BLOOM
Thanks all.
I actually had LR Assist come and take a look. Agreed with me that the trim isn't quite right - he removed the outer piano black trim and used a trim tool to try and pop the seal up - but it seems it's permanent, the dipping of it.
He suggested a dealer fit a new one and that was that.
What's frustrating is, I'll bet the warranty won't cover it so I'm into labour and part. I can't even guess how much it'll be.
I'll take a look at the drains as suggested also! '67 Full Fat RR
'64 Discovery IV
Post #608533 6th Oct 2021 10:47pm
jettec
As I have stated the seal is easy to get at .
You don't need to get JLR to look at.
Have a go its easy.
Post #608535 6th Oct 2021 11:20pm
