![]() | Home > Maintenance & Mods (L405) > Poor ride at 33-40mph and over 70mph |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135 ![]() ![]() ![]() |
What tyres do you have ?
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
I have Pirelli Scorpian Verde's M+S jobbies, not silents. |
Could be some sort of other tyre defect - replacing each wheel in turn with the spare would be the way to eliminate that - if you can be bothered |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
When I bought my Disco I had horrendous shakes at certain speeds….lots of head scratching and fortunately the tyre guy decided to take off a tyre to look. It had about a litre of liquid in it, which turned out to be the left overs from cans of tyre puncture stuff. All 4 had it in! That was enough so when you reached certain speeds, it would all stick in one place and cause the massive wobble. |
The wheels and tires were fitted together about two years ago and I’ve had no issues at all from them the tyres themselves still had the pimples on and had never touched the ground so I can’t believe that anyone has used puncture foam. I did have the tyres checked for being out of shape or having damage but all checked out ok. |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 209 ![]() ![]() |
What about wheel balancing being out, or perhaps a slightly buckled wheel from potholes ? |
The wheels and tyres were checked to be ok by a service centre where I take the family's cars, The guys there are all pretty good and had my car in early AM as a favour. They couldn't find anything. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Upper and lower rear bushes? seeing what you tow? |
Very likely Alex. Never gave that a thought. I wonder if that’s covered on the LR extended warranty. |
I would hope so considering the age of your car ( Don't tell them what you tow |
The warranty book states that it doesn’t cover gradual reduction in operating performance i.e. wear and tear consistent with the age and milage of the vehicle, components that may be subject to wear include but are not limited to brake discs, drums and frictional materials, suspension and steering components, clutch pressure plates, bearings and frictional materials. I’ve covered 64000 miles in 4 1/2 yrs. I would say that’s pretty normal mileage for a car that age. |
With that mileage, you should be ok but you are dealing with JLR I hope you get it sorted out soon |
Hi, Huw, Have you got it sorted? |
