Home > Maintenance & Mods (L322) > L322 Turbo // DPF // Viscous fan advice sought
Deepesh
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Hi there,
My 2011 L322 4.4L TDV8 came up with the red DPF Go to dealer warning light and went into limp mode last week which of course is a pain. I’m having the DPF removed, cleaned and re-installed (roughly £500) rather than getting a new one which would be considerably more. The garage also will charge £120 for a DPF regeneration which I thought was odd as surely if ut has been cleaned, what is there to regenerate? Am I missing something?
When they removed the DPF, they noticed that the (secondary) turbo was leaking oil which is likely the cause of the DPF issue. I’ve received a quote of £1,100 for a reconditioned turbo plus £600 labour. Does this sound about right? Is there no way to repair the turbo instead of replacing it. I’m aware that my mechanic is mostly replace rather than repair chap so I wanted to get a more impartial opinion.
Lastly, he recommends replacing the engine viscous fan for £500 plus £200. Does this seem right?
Any advice / opinions would be much appreciated. I love my L322 but having already spent around £3k on repairs this year, I’m definitely looking for any means of reducing costs now.
Thanks!
Deepesh
Post #609624 18th Oct 2021 5:53pm
JayGee
Maybe get a 2nd opinion from another specialist - which garage was this in London? 2012 TDV8 Vogue (L322)
Post #609637 18th Oct 2021 7:22pm
DrRob
Big Cry Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #609652 18th Oct 2021 9:07pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Viscous fans can be serviced, you can normally strip them apart and change the silicone oil inside and they behave like new. £700 to replace it seems really high. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609654 18th Oct 2021 9:17pm
