![]() | Home > Technical (L322) > 2012 HVAC Auto settings |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I was going to reply….. “From memory, I think that’s about right,” but I’m not sure now 🤣
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 268 ![]() ![]() |
Thanks. Can anyone else help please as it may avoid the dash coming out for the third time. Luckily LR paid for the second one. 2021 3.0 P400 Vogue
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I sometimes get a similar experience to item 1 on your list. My 2012 Westminster will most times 'remember' the HVAC settings, then on odd occasions it all resets to Auto, same as you get. I've just put it down to a 'quirk' with the ECUs.
Had a play about when I was out yesterday.
One thing I have noticed is that the fan sounds much quieter when the AC is switched off. As soon as I turn the AC on, there is a noticeable change in the fan noise and speed, regardless of the temperature setting, even though the fan speed hasn't been changed on the dial. |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
My 61 plate VSE remembers the settings. I have it on auto fan but with all 3 vents open (buttons below the dial) That only changes when SWMBO has driven the car...... |
It’s a very clever system. Blasting air into the cabin at great speed is very uncivilised and not befitting the Range Rover marque 🤣🤣
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Mine always remembers where it was left... |
Thanks all. I’ll speak to my specialist before any further surgery. 2021 3.0 P400 Vogue
