Home > Maintenance & Mods (L322) > Door speaker replacement - bonus cavity rustproofing
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Common occurence of the H/K door speakers blowing, they are clearly not the greatest quality as upon inspection the voice coil seems to have swollen and is now contacting the magnet and causing a scratching sound.
I decided to replace them with a pair of Focal RSE- 165 component speakers, a fair set at £90. I'm not interested in spending £300 on a really good set for our third car.
I stripped off the door panel (which I can do in a matter of 60 seconds now) and whipped out the old H/K speaker from the door and then out completely by desoldering it from the frame.
Its screwed and bonded into the frame so it took a bit of encouragement to come free.
I then checked the polarity of the old unit and confirmed the new drivers have the same terminal orientation and soldered them in.
Here's the Focal speaker in the mounting frame, I used hot glue to secure the foam sound direction ring to the front of the speaker.
While I had the speaker out and the door panel off, I decided to hit the inside of the door with Dinitrol ML. It's great stuff and you can apply it to small areas without breaking out the compressor and shutz gun:
Here's the driver back in the door, only the panel left to refit.
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609978 21st Oct 2021 12:08pm
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
Nice work. I’m in that neck of the woods car wise (door card is off) so I’ll be sure to check mine as well. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #610086 22nd Oct 2021 1:41pm
