![]() | Home > Maintenance & Mods (L405) > Brand New Autobiography windscreen fogging up whilst parked |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
dont forget you can have any temperature setting with the AC, its just that the air will be dry. ... - .- -.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Yes, AC isn’t just for hot weather…. you can condition red hot air if you like….
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
"She knows not to touch the on/off button!"
| Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1096
| marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916
Make sure the AC drain holes are clear. My Transporter van used to do this and when I checked the drains from the aircon the valves at the end of the drain pipes were blocked. Removed them (followed by about a gallon of water) and cleared them out and never had it since. Paul
| Hoyboy Member Since: 21 Oct 2021 Location: London Posts: 79
Touch wood is hasn’t fogged up since I started doing this. Will monitor it but this seems to have solved it. Thanks for everyone’s help! |
| WaterloggedFFRR Member Since: 22 Feb 2022 Location: Louisiana Posts: 6
Just feeling the carpet with your hands isn't good enough. Pull one of the floor sill plates off (they snap
| caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1176
Definitely been caused by AC being off. |
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
Try leaving the AC on these cars do not have a clutch based system they work on pressure.
