Home > Maintenance & Mods (L322) > Buzzing sound from drivers door, where to look next - Solved
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
Very annoying buzzing noise coming from drivers door at 1400rpm. Spent the morning taking the following of in sequence then driving round the block to see if that piece was the culprit. Drivers vent, side trim, door car, window trim, exterior side vent and finally the whole wing mirror. Each time I set off with hope in my heart only to be presented with “haha try again” from the car.
I do have video of the noise but I can’t see any option to upload.
Anyway mate of mine (Chris you should really be on this forum) suggested checking if the buzzing is present with the window door down. Window switches were out but was able use the IID tool control I/O to put the window down and……..bingo no buzzing.
So any ideas or previous experience anyone has of buzzing noises from window assembles?
Also for bonus points why on earth would my RR be saying it is now -40 degrees C. I’m in Qatar and the temperature is the exact opposite of -40. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #610075 22nd Oct 2021 12:54pm
Graham4242
After some more digging it was part of the door stop!
Garage wanted to change the window motor but fortunately I had another look last night.
Problem was I had the door fully open and I couldn’t see it. There is a metal plate on a tapered arm with a pin through it. It had become loose and was buzzing like crazy at 1400rpm. Now all sorted and the drive is back to it normal relaxing self. Current
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #610305 25th Oct 2021 10:35am
i love these 'problem solved' posts...well done chap Thumbs Up ... - .- -.
Post #610306 25th Oct 2021 10:42am
