![]() | Home > Technical (L322) > “Only Normal Height Available” |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
There are many reasons why this could be happening. Do you have access to an IIDtool, or any other diagnostic tool to get the error code?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
I’m guessing that if it can’t be sure the car is actually sat level or at the right height, it will disable the cruise as the adaptive radar can’t be guaranteed to be at the right angle to to road…. So it won’t trust it’s readings either.
DeeJay Member Since: 16 Oct 2021 Location: Western Cape Posts: 41 ![]() ![]() ![]() |
When this happened one time i opened the 4x4 Info page so see if maybe it would indicate a height issue on one of the wheels, and it displayed the vehicle to be level. It also self levels quite nicely with heavy loads. And so im reluctant to assume a height sensor issue. 2011 Vogue SE 4.4 TDV8 |
Negative 2011 Vogue SE 4.4 TDV8 |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Check out the wires on top of the suspension tops under the bonnet if you have adaptive suspension? they could be reconnecting and the parting and you cannot see it? the wires are very thin and get brittle. There is a part replacement from the main dealer? |
The wires for the adaptive suspension has been fiddled with in the past, I dare not take it apart to try do a better job with the tape already used for fear of messing it up even more, especially if I dont experience a problem with it. Im just not quite catching how an EAS activation can trigger an adaptive suspension fault linked to the wires and the error messages I see - care to elaborate pelase? 2011 Vogue SE 4.4 TDV8 |
The trouble will knock out the adaptive cruise as well and something else with the braking it`s like they are all interconnected?
This is an attempt at getting the post to the top of the forum again in case a knowledgeable person didn't see it before. Thanks. 2011 Vogue SE 4.4 TDV8 |
Sure it is a known fault with the appropriate "Adaptive Dynamics Fault" warning message. I do not get this warning message. If it was the case that I need to relook at the wires wouldnt the Adaptive Dynamics warning come up in other situations? 2011 Vogue SE 4.4 TDV8 |
