Home > Maintenance & Mods (L322) > NO power (not limp mode) idle at 500rpm - now non starter .
Page 5 of 8 <12345678>
AJGalaxy2012
cass wrote:
"With the motor spinning over I perceived no build up of pressure on my hand, tho I could feel a little air flow with my hand held just off the exhaust, and the bin bag did not inflate as I would have expected."
I could be wrong but I wouldn't expect to detect any pressure until the engine fired, I'm sure that I've read that engines crank at about 200rpm on the starter? If so then even assuming no leaks or losses that's only about 60L of gas from a 5 second burst of cranking which isn't much to fill an exhaust and all of the other pipework.
does this make any sense?
My take would be 3.6 litres of air moved every 2 revolutions (suck, squeeze, bang, blow 4 stroke). so we should have 100 x 3.6 litres per minute, which is 60 litres per second. 5 seconds cranking should have exhausted 300L of gas in the 5 seconds, remember diesel engines have wide open manifold etc. I feel it should have inflated the bag a bit, well, more than a bit. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #611626 4th Nov 2021 8:59pm
Kevhdkent
Liking your thinking.
But just throws up more questions.
If we’re getting x litres induction, but it’s not exhausting, where’s it going ?
(The induction isn’t pulsing, ie sucking then returning. Just sucking)
Post #611634 4th Nov 2021 10:29pm
Mikey
Unless the turbo has collapsed, and is stopping the air from escaping down the exhaust system...
I'm not saying it's definitely turbo failure, but they are known for it
Takes less than 10 mins to undo the EGR pipes, then we'll know Thumbs Up
Post #611635 4th Nov 2021 10:32pm
AJGalaxy2012
If you consider all the valves open or cam stationary, one piston moving up exhausting, another will be going down so the displacement would be small.
Drop the EGR pipes off and then we will know as mickey said. I think we’re getting close now. BMW i3 Electric Car
Post #611638 4th Nov 2021 11:19pm
Kevhdkent
Appreciate all the input
I will attack the EGR pipes at the weekend, in daylight.
Post #611654 5th Nov 2021 9:30am
Kot
Re: NO power (not limp mode) idle at 500rpm - now non starte
Kevhdkent wrote:
2008 TDV8 3.6
Close to giving up Sad after a month of failed diagnostics.
Cruising at 50/60mph with trailer, uneventful no issues for 150 miles, then suddenly rpm drops to 500 and complete loss of power with no throttle response. BUT IT DOES NOT CUT OUT.
Cruise, NOT coast, 1/4 mile into a lay-by where she sits at a very low 500rpm idle, no throttle response, until I turn her off.
Never to start again Big Cry
To be clear, there were no pops or bangs grinds mechanics sounds or lumpiness in the running, just low rpm & no throttle response.
This is a great read and believe it or not I went to bed thinking about this and when I woke it was still on my mind--God I am sad Rolling with laughter But great fault finding and every input made with good intent---great forum!
But what's nagging away at me is the quote above. The Engine never stopped, stayed at 500rpm until driver intervened, never to start again. It does not suggest major failure.
1 I Presume the throttle is a electrical/electronic?
If this failed, surely the ECU will prevent a run away/or a sudden stop while running at speed (possible towing etc) and possibly at night for safety reasons?
In such an event surely ECU will be programmed to ensure enough revs (500 rpm) to maintain system workability lights brakes suspension etc enough to enable driver to intervene and coast to a safe place, then when stopped prevent further start.
2 Also--Surely the crank position sensor will be in the same circuit (another input to same ECU), as it measures engine speed, and if that failed in use while driving, the same program in the ECU would do the same.
So the ECU would monitor these 2 inputs among other things, and when something strange happens it will be programmed to have such a response?
Has any member experience any of this 2 failures while driving? Interesting to know what experience you had
Now I can go back to bed Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #611658 5th Nov 2021 10:05am
GraemeS
Australia
The throttle is referred to as a driver demand sensor, to which the ecm reacts as it has been programmed. The throttle doesn't have any direct control.
My introduction to failing crankshaft position sensors was many years ago on a relatively new petrol-engined vehicle on which the engine would randomly stop, although more often after half an hour's driving. No fault codes stored so the technicians progressively swapped components with another new vehicle until they swapped the crankshaft position sensor, after which the fault didn't re-occur. I've since encountered faulty crankshaft position sensors in various vehicles, some of which worked when cooled by spraying with a can of soft-drink but none ever recorded a fault code. Hence it's one of the first components that I check when an engine fails to run without having stored any fault codes. The ability of modern diagnostic tools to monitor live values removes the guess-work for this sensor.
Post #611663 5th Nov 2021 10:45am
kevinp
Agree with GraemeS. I had a Ford Explorer that either would start or wouldn't. Once started it was fine. One day it wouldn't start. RAC came out and just wiggled the electrical connector on the crankshaft sensor and it started!! So mine wasn't even the sensor. Cleaned connector and no more trouble. Worth trying.
Post #611682 5th Nov 2021 12:59pm
Kot
It does have direct control if it fails.
Extract from WSM
"The APP sensor (Accelerator Pedal Position sensor) signals are checked for range and plausibility. Two separate reference voltages are supplied to
the pedal. Should one sensor fail, the other is used as a 'limp – home' input. In limp home mode due to an APP
signal failure the ECM will limit the maximum engine speed 2000 RPM.
The APP sensor has two potentiometer tracks which each receive a 5V input voltage from the ECM. Track 1
provides an output of 0.5V with the pedal at rest and 2.0V at 100% full throttle. Track 2 provides an output of
0.5V with the pedal at rest and 4.5V at 100% full throttle. The signals from the two tracks are used by the ECM
to determine fueling for engine operation"
The ECM monitors the outputs from each of the potentiometer tracks and can determine the position, rate of
change and direction of movement of the throttle pedal. The 'closed throttle' position signal is used by the ECM
to initiate idle speed control and also overrun fuel cut-off.
So we can see if 1 track fails, then limp home allowed at 2000rpm. But what if both tracks fail and failed at zero voltage (broken wire/bad connection) Do you think it would allow limp home then? I wonder in this scenario, the ECM has a built in safety program to go to idle and not allow a restart?
Interesting info about your experience regarding crank sensor, (Engine stopping and not starting) but this does not explain why this engine was still running at 500rpm and looked like it would continue at that rpm, until the driver shut it down. 2018 SE SDV8 4.4 Byron Blue
Post #611688 5th Nov 2021 1:57pm
cass
I stand corrected (partly), my mental arithmetic is slipping, 3.6L x 100 = 360L/min MAX? = 6L/second = 30L per 5 second crank MAX assuming no leaks/losses which isn't very likely, so even less chance of blowing a bag up?
All the more reason to follow the guidance of the likes of Mikey and ignore the rest of us! Laughing
Post #611706 5th Nov 2021 4:21pm
Kot
cass wrote:
I'm not normally a fan of buying bits and hoping it will fix it BUT when logic and common sense don't work I've repeatedly found that crankshaft position sensors have been to blame where there are intermittent and unpredictable problems.
It isn't expensive or too difficult to fit so that would be my next guess.
You have changed your tune since this post any reason Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #611719 5th Nov 2021 5:38pm
cass
Yes - I thought I'd sit quietly then look for the "smug tw@" emoji if it turns out to be the sensor Laughing
But I always try to follow some kind of logical path when fault finding (or at least something that looks logical to me), it's too easy to take a scattergun approach and end up getting nowhere hence my suggestion to follow Mikeys plan.
Post #611738 5th Nov 2021 7:12pm
Kevhdkent
Kot wrote:
Kevhdkent wrote:
2008 TDV8 3.6
The fact that the motor continue to idle at low rpm for some minutes before I turned the ignition off is something I have to keep highlighting. It eliminates most of the “catastrophic” suggestions such as snapped camchain etc.
Post #611746 5th Nov 2021 8:03pm
Kevhdkent
That’s my plan, but Due to my working on a construction site, this time of year that’s dawn to dusk, I’ve been gleaning all the info and suggestions I can. So tomoz the work starts. Basically I’ll be looking at those items which are most accessible.
Not helped by it being sat half on the road outside as I can’t move it onto the drive or into the shelter of the garage 😩😩
Post #611747 5th Nov 2021 8:11pm
Good luck Thumbs Up Pete
-Click here for Thread-
Post #611755 5th Nov 2021 9:39pm
