![]() | Home > Technical (L322) > Rumbling and vibration |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Drove the old girl 95 miles into North Norfolk yesterday and noticed there is a vibration through the car at 40-65 mph and it doesn’t feel like it’s coming from any corner in particular.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Sticky rear brake callipers are a fairly common issue. If a wheel is hotter to the touch…. 2011 Range Rover Vogue SE 4.4 TDV8
Thanks for the heads up. I’ll check them too Christian.
Prop shaft is out, anyone know how to separate the halves that are bolted together in the UJ?
I absolutely cannot get these parts apart. Anyone for any ideas?
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 ![]() ![]() ![]() |
Maybe look in the WM page 283/284?
Perseverance and an air hammer.
Good job done. |
So following the propshaft centre support bearing replacement and subsequent discovery of sticking rear calliper, I've also refurbished both rear callipers with new pistons and seals and now my rear brakes are working as intended!
