Home > Maintenance & Mods (L322) > 3.6 TDV8 rear diff fill plug
Rudyard
Hello all, my first post here so please bear with me! I have been servicing the car this week and have become stumped on the rear diff - mine is a standard diff and I can’t seem to find the fill plug? (Or basically the local LR dealer have given me the wrong plugs!
Front diff was fine - could not believe the 1cm thick lump of grey metal paste glued to the magnet of the diff plug though! Worrying……
Any help or pictures that can be spared would be really appreciated.
2007 TDv8 3.6
Post #610917 29th Oct 2021 11:06am
Rambles
Haven’t done an 07 rear diff before....
I would have guessed fill plug is on the top half, either left or right hand side
I have seen some comment that you need a 14mm Hex Drive for rear diffs.
There is a YouTube service of a front and rear diff, plus transfer box oil service for an 07 plate L322. Poster name is Nut Job.
The clip is cut short and doesn’t show the rear diff.
Poster reckons the drain hole was right at the bottom of the diff and took a 3/8th Drive, and the fill plug took a 7mm hex drive / Allen key.
Were you expecting to find the fill plug needs a 14mm hex ? Hence the Q if you were given wrong size fill plugs?
Not a disaster to re-use fill plugs ......
Post #611200 31st Oct 2021 6:45pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
Just be careful to measure how much oil goes in. The old adage of when it spills it's right ! doesn't apply for the L322. The only car I know where this is the case.
Post #611268 1st Nov 2021 10:32am
kevinp
As long as you haven't damaged the plug when removing it, just wrap a couple of turns of PTFE tape around the threads and reuse your old plug.
Post #611287 1st Nov 2021 12:22pm
Rudyard1
Feel like I need to say thanks for the help guys - I tried to log in to my account but password forgotten. Tried a reset but admin wouldn’t really help me so I’ve had to create a new login. Never mind - first poster and all that!
I managed to sort the rear diff oil - I will do a separate write up as I feel definitely worth doing it - don’t know if this is all in my head but the drivetrain in general feels a lot smoother. May do a wiki if the mods will allow it? (I suggest that as I was given the wrong fill plug by dealership and thus doubted my ability to even do the job!)
Thanks again
Post #612715 15th Nov 2021 2:47pm
Rudyard1
Thought I should also add it’s worth doing - especially when you see just how much the magnets pick up!
From the pics you can actually see the depth of the metallic crud that is glued to it!
Post #613217 20th Nov 2021 10:10am
Rudyard1
Pics
Post #613218 20th Nov 2021 10:12am
ajac8
Hope this works... changed a pdf to a jpeg...
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #613222 20th Nov 2021 10:44am
