Home > Technical (L322) > L322 Light Control module - YWC000540 replacement
24valve
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Afternoon All,
I've got a fault showing on the GAP diagnostics relating to the air suspension (0x57 air suspension active/inactive), but the fault is resident in the light control module.
I suspect that the LCM has got a bit damp in the past, but the fault doesnt go away if I try and clear it.
If I swap the LCM with another one, do they have to be coded to the car?
Theres a thread (on another forum) where someone suspects that it does, but I think they are relating to the BCM, not LCM as is the case here.
If it does, I dont suppose my new GAP tool can do this can it?!
Neil. 2010 L322 Autobiography Black Edition
1975 Land Rover
Post #611191 31st Oct 2021 5:41pm
jm1489
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi, did you get an answer to your post? My LCM is playing up, looking at a BMW replacement but not sure if it needs coding... doubt it but you never know?
Post #664304 17th May 2023 12:17am
